multistream_select
Struct NegotiatedComplete
Source
pub struct NegotiatedComplete<TInner> { /* private fields */ }
Expand description
A Future that waits on the completion of protocol negotiation.
Trait Implementations§
Source§
impl<TInner: Debug> Debug for NegotiatedComplete<TInner>
Source§
fn fmt(&self, f: &mut Formatter<'_>) -> Result
Formats the value using the given formatter. Read more
Source§
impl<TInner> Future for NegotiatedComplete<TInner>
where TInner: AsyncRead + AsyncWrite + Unpin,
Source§
type Output = Result<Negotiated<TInner>, NegotiationError>
The type of value produced on completion.
Source§
fn poll(self: Pin<&mut Self>, cx: &mut Context<'_>) -> Poll<Self::Output>
Attempts to resolve the future to a final value, registering the current task for wakeup if the value is not yet available. Read more
Auto Trait Implementations§
impl<TInner> Freeze for NegotiatedComplete<TInner>
where TInner: Freeze,
impl<TInner> RefUnwindSafe for NegotiatedComplete<TInner>
where TInner: RefUnwindSafe,
impl<TInner> Send for NegotiatedComplete<TInner>
where TInner: Send,
impl<TInner> Sync for NegotiatedComplete<TInner>
where TInner: Sync,
impl<TInner> Unpin for NegotiatedComplete<TInner>
where TInner: Unpin,
impl<TInner> UnwindSafe for NegotiatedComplete<TInner>
where TInner: UnwindSafe,
Blanket Implementations§
Source§
impl<T> Any for T
where T: 'static + ?Sized,
Source§
fn type_id(&self) -> TypeId
Gets the TypeId of self. Read more
Source§
impl<T> Borrow<T> for T
where T: ?Sized,
Source§
fn borrow(&self) -> &T
Immutably borrows from an owned value. Read more
Source§
impl<T> BorrowMut<T> for T
where T: ?Sized,
Source§
fn borrow_mut(&mut self) -> &mut T
Mutably borrows from an owned value. Read more
Source§
impl<T> From<T> for T
Source§
fn from(t: T) -> T
Returns the argument unchanged.
Source§
impl<T> FutureExt for T
where T: Future + ?Sized,
Source§
fn map<U, F>(self, f: F) -> Map<Self, F>
where F: FnOnce(Self::Output) -> U, Self: Sized,
Map this future’s output to a different type, returning a new future of the resulting type. Read more
Source§
fn map_into<U>(self) -> MapInto<Self, U>
where Self::Output: Into<U>, Self: Sized,
Source§
fn then<Fut, F>(self, f: F) -> Then<Self, Fut, F>
where F: FnOnce(Self::Output) -> Fut, Fut: Future, Self: Sized,
Chain on a computation for when a future finished, passing the result of the future to the provided closure f. Read more
Source§
fn left_future<B>(self) -> Either<Self, B>
where B: Future<Output = Self::Output>, Self: Sized,
Wrap this future in an Either future, making it the left-hand variant of that Either. Read more
Source§
fn right_future<A>(self) -> Either<A, Self>
where A: Future<Output = Self::Output>, Self: Sized,
Wrap this future in an Either future, making it the right-hand variant of that Either. Read more
Source§
fn into_stream(self) -> IntoStream<Self>
where Self: Sized,
Convert this future into a single element stream. Read more
Source§
fn flatten(self) -> Flatten<Self>
where Self::Output: Future, Self: Sized,
Flatten the execution of this future when the output of this future is itself another future. Read more
Source§
fn flatten_stream(self) -> FlattenStream<Self>
where Self::Output: Stream, Self: Sized,
Flatten the execution of this future when the successful result of this future is a stream. Read more
Source§
fn fuse(self) -> Fuse<Self>
where Self: Sized,
Fuse a future such that poll will never again be called once it has completed. This method can be used to turn any Future into a FusedFuture. Read more
Source§
fn inspect<F>(self, f: F) -> Inspect<Self, F>
where F: FnOnce(&Self::Output), Self: Sized,
Do something with the output of a future before passing it on. Read more
Source§
fn catch_unwind(self) -> CatchUnwind<Self>
where Self: Sized + UnwindSafe,
Catches unwinding panics while polling the future. Read more
Source§
fn shared(self) -> Shared<Self>
where Self: Sized, Self::Output: Clone,
Create a cloneable handle to this future where all handles will resolve to the same result. Read more
Source§
fn remote_handle(self) -> (Remote<Self>, RemoteHandle<Self::Output>)
where Self: Sized,
Turn this future into a future that yields () on completion and sends its output to another future on a separate task. Read more
Source§
fn boxed<'a>(self) -> Pin<Box<dyn Future<Output = Self::Output> + Send + 'a>>
where Self: Sized + Send + 'a,
Wrap the future in a Box, pinning it. Read more
Source§
fn boxed_local<'a>(self) -> Pin<Box<dyn Future<Output = Self::Output> + 'a>>
where Self: Sized + 'a,
Source§
fn unit_error(self) -> UnitError<Self>
where Self: Sized,
Source§
fn never_error(self) -> NeverError<Self>
where Self: Sized,
Source§
fn poll_unpin(&mut self, cx: &mut Context<'_>) -> Poll<Self::Output>
where Self: Unpin,
A convenience for calling Future::poll on Unpin future types.
Source§
fn now_or_never(self) -> Option<Self::Output>
where Self: Sized,
Evaluates and consumes the future, returning the resulting output if the future is ready after the first call to Future::poll. Read more
Source§
impl<T, U> Into<U> for T
where U: From<T>,
Source§
fn into(self) -> U
Calls U::from(self).
That is, this conversion is whatever the implementation of From<T> for U chooses to do.
Source§
impl<F> IntoFuture for F
where F: Future,
Source§
type Output = <F as Future>::Output
The output that the future will produce on completion.
Source§
type IntoFuture = F
Which kind of future are we turning this into?
Source§
fn into_future(self) -> <F as IntoFuture>::IntoFuture
Creates a future from a value. Read more
Source§
impl<T, U> TryFrom<U> for T
where U: Into<T>,
Source§
type Error = Infallible
The type returned in the event of a conversion error.
Source§
fn try_from(value: U) -> Result<T, <T as TryFrom<U>>::Error>
Performs the conversion.
Source§
impl<F, T, E> TryFuture for F
where F: Future<Output = Result<T, E>> + ?Sized,
Source§
type Ok = T
The type of successful values yielded by this future
Source§
type Error = E
The type of failures yielded by this future
Source§
fn try_poll( self: Pin<&mut F>, cx: &mut Context<'_>, ) -> Poll<<F as Future>::Output>
Poll this TryFuture as if it were a Future. Read more
Source§
impl<Fut> TryFutureExt for Fut
where Fut: TryFuture + ?Sized,
Source§
fn flatten_sink<Item>(self) -> FlattenSink<Self, Self::Ok>
where Self::Ok: Sink<Item, Error = Self::Error>, Self: Sized,
Flattens the execution of this future when the successful result of this future is a Sink. Read more
Source§
fn map_ok<T, F>(self, f: F) -> MapOk<Self, F>
where F: FnOnce(Self::Ok) -> T, Self: Sized,
Maps this future’s success value to a different value. Read more
Source§
fn map_ok_or_else<T, E, F>(self, e: E, f: F) -> MapOkOrElse<Self, F, E>
where F: FnOnce(Self::Ok) -> T, E: FnOnce(Self::Error) -> T, Self: Sized,
Maps this future’s success value to a different value, and permits for error handling resulting in the same type. Read more
Source§
fn map_err<E, F>(self, f: F) -> MapErr<Self, F>
where F: FnOnce(Self::Error) -> E, Self: Sized,
Maps this future’s error value to a different value. Read more
Source§
fn err_into<E>(self) -> ErrInto<Self, E>
where Self: Sized, Self::Error: Into<E>,
Maps this future’s Error to a new error type using the Into trait. Read more
Source§
fn ok_into<U>(self) -> OkInto<Self, U>
where Self: Sized, Self::Ok: Into<U>,
Maps this future’s Ok to a new type using the Into trait.
Source§
fn and_then<Fut, F>(self, f: F) -> AndThen<Self, Fut, F>
where F: FnOnce(Self::Ok) -> Fut, Fut: TryFuture<Error = Self::Error>, Self: Sized,
Executes another future after this one resolves successfully. The success value is passed to a closure to create this subsequent future. Read more
Source§
fn or_else<Fut, F>(self, f: F) -> OrElse<Self, Fut, F>
where F: FnOnce(Self::Error) -> Fut, Fut: TryFuture<Ok = Self::Ok>, Self: Sized,
Executes another future if this one resolves to an error. The error value is passed to a closure to create this subsequent future. Read more
Source§
fn inspect_ok<F>(self, f: F) -> InspectOk<Self, F>
where F: FnOnce(&Self::Ok), Self: Sized,
Do something with the success value of a future before passing it on. Read more
Source§
fn inspect_err<F>(self, f: F) -> InspectErr<Self, F>
where F: FnOnce(&Self::Error), Self: Sized,
Do something with the error value of a future before passing it on. Read more
Source§
fn try_flatten(self) -> TryFlatten<Self, Self::Ok>
where Self::Ok: TryFuture<Error = Self::Error>, Self: Sized,
Flatten the execution of this future when the successful result of this future is another future. Read more
Source§
fn try_flatten_stream(self) -> TryFlattenStream<Self>
where Self::Ok: TryStream<Error = Self::Error>, Self: Sized,
Source§
fn unwrap_or_else<F>(self, f: F) -> UnwrapOrElse<Self, F>
where Self: Sized, F: FnOnce(Self::Error) -> Self::Ok,
Unwraps this future’s output, producing a future with this future’s Ok type as its Output type. Read more
Source§
fn into_future(self) -> IntoFuture<Self>
where Self: Sized,
Wraps a TryFuture into a type that implements Future. Read more
Source§
fn try_poll_unpin( &mut self, cx: &mut Context<'_>, ) -> Poll<Result<Self::Ok, Self::Error>>
where Self: Unpin,
A convenience method for calling TryFuture::try_poll on Unpin future types.
Source§
impl<T, U> TryInto<U> for T
where U: TryFrom<T>,
Source§
type Error = <U as TryFrom<T>>::Error
Source§
fn try_into(self) -> Result<U, <U as TryFrom<T>>::Error>
